20 years agoProblem dloading vmlinux to 2C35
Hi, I was trying to download the vmlinux.flash image to the board and received this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processo...
20 years agoFinally, I borrowed a CycloneII dev board, and worked out.
You should have quartusII v5.1 sp1, and NiosII v5.1 sp1. There is no need to strip the vmlinux. First open the project and download the sof of your board with QuartusII programmer. eg, if you use CycloneII dev board, it is altera/kits/nios2/examples/verilog/niosII_cycloneII_2c35/standard/ standard.sof Next, open two "Nios II SDK shell" windows. From one, run "nios2-terminal". From two, run "nios2-download -g vmlinux"
