20 years agoProblem dloading vmlinux to 2C35
Hi, I was trying to download the vmlinux.flash image to the board and received this error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processo...
20 years agoI did a
strip --target=srec vmlinux and the original 8314kb got skimmed down to 7685kb, which still seems quite big. Should I be using some other options? And where is the system library I should be looking for to set to RAM rather than FLASH? Sorry if the question seems a bit basic but if you don't mind giving step by step instructions for that? Thanks a lot!
