17 years ago
problem developing zImage (uClinux)
I followed steps followed in
http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist (http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist)
everything goes well untill
make vendor_hwselect SYSPTF=/path_to_your_hardware_project/your_system.ptf
But when I use the make command it gives an error
[root@localhost uClinux-dist]# NON_SMP_BUILD=1 make
make -C tools/ucfront
make[1]: Entering directory `/root/Desktop/uClinux-dist/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/root/Desktop/uClinux-dist/tools/ucfront'
ln -sf /root/Desktop/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /root/Desktop/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /root/Desktop/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld
chmod +x tools/romfs-inst.sh tools/modules-alias.sh
. linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then
mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`;
touch $CONFIG_INITRAMFS_SOURCE || exit 1;
fi
dirname: extra operand `../vendors/Altera/nios2nommu/romfs_list'
Try `dirname --help' for more information.
mkdir: missing operand
Try `mkdir --help' for more information.
touch: cannot touch `../vendors/Altera/nios2nommu/romfs_list': No such
file or directory
make: *** [linux] Error 1
can any1 help me in removing this error..
Thanx a lot !!!
    Thank you for the reply..
    with the new link while trying to build the toolchain
    when I put command
    >setarch i386 make gcc elf2flt gdb-host
    it gives an error
    make[1]: Entering directory `/root/Desktop/nios2-linux/uClibc'
    make[2]: `conf' is up to date.
    make[2]: execvp: true: Permission denied
    make[2]: *** [headers-y] Error 127
    make[1]: *** [headers] Error 2
    make[1]: Leaving directory `/root/Desktop/nios2-linux/uClibc'
    make: *** [/root/Desktop/nios2-linux/toolchain-build/build/sysroot//.configured]
    Error 2
    m stuck and dont know what to do ...
