21 years agoProblem debugging on a custom cyclone board
Hi: This is just about getting us crazy. We have designed a custom board with a Cyclone chip for implementing a NIOS II processor, both the processor and the SDRAM seem to work ok (some impleme...
21 years agoJust for others to note:
The reason SDRAM access worked with GERMS is that subtle memory timing problems will not reveal themselves as a result of the CPU data master accessing RAM -- the data master performs one read or write every once in a while, but not continuously. By contrast, instruction fetch (and cache fills) will exercise the SDRAM interface with a new word of data on each clock. If there is a subtle timing problem, such as setup/hold violations due to clock-phase-shifts, then these will be manifested when you try to run code from SDRAM, or do something like a DMA transfer.
