21 years agoProblem configuring kernel.
Here's the output when I try to configure linux 2.6 kernel for nios II. crt0.o is found on the computer in several places, where should it be?. Should I have some environment variable set o...
21 years agoHiya again!
I happened to look at mounts from the shell and noticed that nonexistent directory C:\quartus\bin\cygwin\lib was mounted on /usr/lib just unmounting this with "umount /usr/lib" fixed the problem. (Didn't even have to mount C:\quartus\bin\cygwin\usr\lib to /usr/lib, lib directory was in right place after the unmount) Why this happens on this computer but not on the next one is a mystery to me. But anyway, problem solved. Thanks for all the help. -Tervis
