21 years agoProblem configuring kernel.
Here's the output when I try to configure linux 2.6 kernel for nios II. crt0.o is found on the computer in several places, where should it be?. Should I have some environment variable set o...
21 years agoHi Tervis, sorry for not replying earlier, but I don't recall ever getting notification of your reply.
At any rate, regarding the issue around the /usr/lib under Cygwin... I'm at a loss as to why you're experiencing those problems. I would try DavidBrown's suggestion, it's more than reasonable. Let us know how it goes and if problems persist, I'll see if I can duplicate your environment on a test machine here for testing purposes.
