21 years agoProblem configuring kernel.
Here's the output when I try to configure linux 2.6 kernel for nios II. crt0.o is found on the computer in several places, where should it be?. Should I have some environment variable set o...
21 years agoI have the lib directory in C:\quartus\bin\cygwin\usr, but when I go to a bash shell there is no /usr/lib directory at all.
I created a file in C:\quartus\bin\cygwin\usr and it appeared in the shell under /usr so there should be a lib directory too, by my logic at least. Attributes of the lib directory seemed to be okay, they were the same as the other directories in /usr, which are visible in both places. What the heck is wrong here? -Tervis
