21 years agoProblem configuring kernel.
Here's the output when I try to configure linux 2.6 kernel for nios II. crt0.o is found on the computer in several places, where should it be?. Should I have some environment variable set o...
21 years agoThe one you're looking for should be in the following directory:
<cygwin>/usr/lib If you don't have it, let me know and I'll send you a copy. As a side note, I'm not sure why it wasn't installed with your Nios II Linux Distribution... is there anything that may be unique to your workstation (cygwin-wise) that you think may not be on most workstations?
