20 years agoProblem building hello_world
Hey anyone I have this problem. I have bought a cyclone dev. kit. and used the standard niosII_cyclone_1c20 form the example list in Quartus. this kan be compiled with no error. But when i t...
20 years agoHmm, in my NIOS 5.1 installation sh_launch.pm exists in the altera\kits\nios2_51\bin directory so the script should find it. Check to see if you have that file. Also check the case, I think it might be case sensitive.
The existing project probably works because it doesn't have to run generated_app.mk. This only happens when your NIOS design changes. Andrew
