Problem booting latest version of nios2 uClinux
I have the latest version of nios2 uClinux using the dts file created from sopcinfo. I never see the "Uncompressing Linux... Ok, booting the kernel." message before the Linux startup. This leads me to believe the file system is not being extracted to the memory. Does anyone know what would be causing this?
Linux version 3.4.0+ (root@server) (gcc version 4.1.2)# 360 PREEMPT Wed May 23 12:29:37 EDT 2012
bootconsole enabled
early_console initialized at 0xf0008d20
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c846314c, node_mem_map c8476280
DMA zone: 256 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 32512 pages, LIFO batch:7
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: debug console=ttyAL0,115200 init=/bin/init
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory available: 125344k/4557k RAM (1953k kernel code, 2603k data)
NR_IRQS:64
Calibrating delay loop... 30.31 BogoMIPS (lpj=151552)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
Switching to clocksource timer
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered (default)
ttyAL0 at MMIO 0x10008d20 (irq = 5) is a Altera UART
console enabled, bootconsole disabled
spi_altera 10007c00.spi: master is unqueued, this is deprecated
m25p80 spi32766.0: found m25p64, expected m25p80
m25p80 spi32766.0: m25p64 (8192 Kbytes)
spi_altera 10007c00.spi: base f0007c00, irq 4
altera_tse-mdio: probed
eth0: Altera TSE MAC at 0xf0008400 irq 2/1
eth0: Reporting available PHYs:
eth0: PHY with ID 0x20005c7a at 0x1
eth1: Altera TSE MAC at 0xf0008800 irq 7/6
eth1: Reporting available PHYs:
TCP: cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 2308k freed (0xc81ea000 - 0xc842b000)
Failed to execute /init
Failed to execute /bin/init. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.14 Replies
--- Quote Start --- What linker script are you referring to? I do not see any links to the root file system. --- Quote End --- Please search the file 'vmlinux.lds' or 'vmlimux.lds.S'. It's the linker script, and you will find the linking position of 'init.ramfs'. --- Quote Start --- I also tried uploading the vmlinux file to the FPGA but it gives the same error message as before. --- Quote End --- It's quite natural when your kernel does not include 'init.ramfs'. The files zImage etc. are only compressed ones of 'vmlinux'. --- Quote Start --- Has anyone built the latest version of uClinux for NIOS2 and has it working? --- Quote End --- At least, the maintainers do it. And of course, you select 'Initial RAM filesystem' in the menuconfig like
? Kazu─ General setup --> Create deprecated sysfs layout for older userspace tools Kernel->user space relay support (formerly relayfs) Namespaces support Initial RAM filesystem and RAM disk (initramfs/initrd) suppor () Initramfs source file(s) Support initial ramdisks compressed using gzip Support initial ramdisks compressed using bzip2 Support initial ramdisks compressed using LZMA - Altera_Forum
--- Quote Start --- There are two vmlinux.lds files in the linux-2.6.x directory. The file in the arch/nios2/boot/compressed does not have the .init.ramfs reference. The file in the arch/nios2/kernel does have the .init.ramfs reference. --- Quote End --- You must use the linker script which contains the .init.ramfs reference. --- Quote Start --- Also, I have to configure the "Initramfs source file(s)" in the menuconfig "General setup" with "../romfs ../vendors/Altera/nios2/romfs_list" or I get this error message.
--- Quote End --- Of course, your downloaded program does not contain the 'root file system'. Maybe, your linking process causes these errors. KazuNo filesystem could mount root, tried: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) - Altera_Forum
I have an older version of uClinux 2.6.35 that compiles and uploads to the FPGA with this SOPC design. I compared the linker scripts with the old uClinux version and the new uClinux version and there is not much difference between the files. I don't see any problems with the linker scripts. Do you have any other suggestions?
Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.35-00743-ge3b9b64-dirty (root@server) (gcc version 4.1.2)# 2127 Fri Jan 13 14:47:19 EST 2012 bootconsole enabled early_console initialized at 0xf0007120 Linux/Nios II-MMU init_bootmem_node(?,0x83c9, 0x8000, 0x10000) free_bootmem(0x83c9000, 0x7c37000) reserve_bootmem(0x83c9000, 0x1000) Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) We have 65536 pages of RAM Memory available: 126060k/3875k RAM, 0k/0k ROM (1692k kernel code, 2183k data) Hierarchical RCU implementation. RCU-based detection of stalled CPUs is disabled. Verbose stalled-CPUs detection is disabled. NR_IRQS:32 Calibrating delay loop... 30.51 BogoMIPS (lpj=152576) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 Switching to clocksource timer NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 246 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) ttyS0 at MMIO 0x10007120 (irq = 5) is a Altera UART console enabled, bootconsole disabled console enabled, bootconsole disabled m25p80 spi0.0: found m25p64, expected m25p80 m25p80 spi0.0: m25p64 (8192 Kbytes) Creating 2 MTD partitions on "m25p80": 0x000000780000-0x000000800000 : "romfs/jffs2" 0x000000000000-0x000000780000 : "fpga configuration" Altera TSE MII Bus: probed Found PHY with ID=0x20005c7a at address=0x1 Altera Triple Speed MAC IP Driver(v8.0) developed by SLS,August-2008 Altera SFP TSE MII Bus: probed Found PHY with ID=0x20005c7a at address=0x0 Altera SFP Triple Speed MAC IP Driver(v8.0) developed by SLS,August-2008 TCP cubic registered NET: Registered protocol family 17 Freeing unused kernel memory: 1724k freed (0xc81a8000 - 0xc8356000) Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ BusyBox v1.18.2 (2012-01-12 12:55:58 EST) hush - the humble shell Enter 'help' for a list of built-in commands. /# - Altera_Forum
Did you resolve this issue, I also have the problem that zImage doesn't contain .init.ramfs reference when using nios2-linux-readelf -a zImage.
I would appreciate any hints on why the linker doesn't do this automatically (isn't it supposed to?)
