14 years agoProblem booting latest version of nios2 uClinux
I have the latest version of nios2 uClinux using the dts file created from sopcinfo. I never see the "Uncompressing Linux... Ok, booting the kernel." message before the Linux startup. This leads me t...
14 years agoHi,
--- Quote Start --- What linker script are you referring to? I do not see any links to the root file system. --- Quote End --- Please search the file 'vmlinux.lds' or 'vmlimux.lds.S'. It's the linker script, and you will find the linking position of 'init.ramfs'. --- Quote Start --- I also tried uploading the vmlinux file to the FPGA but it gives the same error message as before. --- Quote End --- It's quite natural when your kernel does not include 'init.ramfs'. The files zImage etc. are only compressed ones of 'vmlinux'. --- Quote Start --- Has anyone built the latest version of uClinux for NIOS2 and has it working? --- Quote End --- At least, the maintainers do it. And of course, you select 'Initial RAM filesystem' in the menuconfig like
─ General setup -->
Create deprecated sysfs layout for older userspace tools
Kernel->user space relay support (formerly relayfs)
Namespaces support
Initial RAM filesystem and RAM disk (initramfs/initrd) suppor
() Initramfs source file(s)
Support initial ramdisks compressed using gzip
Support initial ramdisks compressed using bzip2
Support initial ramdisks compressed using LZMA
? Kazu
