14 years agoProblem booting latest version of nios2 uClinux
I have the latest version of nios2 uClinux using the dts file created from sopcinfo. I never see the "Uncompressing Linux... Ok, booting the kernel." message before the Linux startup. This leads me t...
14 years ago --- Quote Start --- And which file did you download? --- Quote End --- There are two files in the images directory. romfs-inst.log (2353 bytes) zImage (3293581 bytes) After uploading the SOF file I upload the zImage file to the FPGA. --- Quote Start --- And What message does your 'make' say in the last part of build process? --- Quote End ---
make ARCH=nios2 -C vendors image
make: Entering directory `/root/nios2-linux/uClinux-dist/vendors'
make -C /root/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/root/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /root/nios2-linux/uClinux-dist/vendors/vendors-common.mak image
make: Entering directory `/root/nios2-linux/uClinux-dist/vendors/Altera/nios2'
|| mkdir -p /root/nios2-linux/uClinux-dist/images
chmod -R +x /root/nios2-linux/uClinux-dist/romfs/bin
rm /root/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz
LDFLAGS="" make ARCH=nios2 CROSS_COMPILE=nios2-linux-gnu- -C /root/nios2-linux/uClinux-dist/../linux-2.6 O=/root/nios2-linux/uClinux-dist/linux-2.6.x zImage
make: Entering directory `/root/nios2-linux/linux-2.6'
Using /root/nios2-linux/linux-2.6 as source for kernel
GEN /root/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
CHK include/linux/version.h
CHK include/generated/utsrelease.h
CALL /root/nios2-linux/linux-2.6/scripts/checksyscalls.sh
cc1: warning: include location "/usr/local/include" is unsafe for cross-compilation
CHK include/generated/compile.h
GEN usr/initramfs_data.cpio.gz
AS usr/initramfs_data.o
LD usr/built-in.o
DTC arch/nios2/boot/system.dtb
DTC: dts->dtb on file "/root/nios2-linux/linux-2.6/../linux-2.6/arch/nios2/boards/wim_mmu/wim.dts"
AS arch/nios2/boot/linked_dtb.o
LD arch/nios2/boot/built-in.o
LD vmlinux.o
MODPOST vmlinux.o
GEN .version
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
LD vmlinux
SYSMAP System.map
OBJCOPY arch/nios2/boot/vmlinux.bin
GZIP arch/nios2/boot/vmlinux.gz
LD arch/nios2/boot/compressed/piggy.o
LD arch/nios2/boot/compressed/vmlinux
OBJCOPY arch/nios2/boot/zImage
Kernel: arch/nios2/boot/zImage is ready
make: Leaving directory `/root/nios2-linux/linux-2.6'
cp /root/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/zImage /root/nios2-linux/uClinux-dist/images/zImage
make: Leaving directory `/root/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make: Leaving directory `/root/nios2-linux/uClinux-dist/vendors'
