16 years agoProblem about the Pin planner of SOPC core
I bulid a system with SOPC builder. And I only use six components ,CPU ,JtAG Uart ,system id, Pio*3 and pll. The PIO that two is 16 bits output signal, the other one is 1 bit output signal. t...
16 years ago --- Quote Start --- In the schematic you posted, I see that g output pin seems to be connected to a bus wire. Is there a mistake or is it simply a problem with the bitmap image? Anyway, please, explain better your problem. Which device works and which doesn't? The problem is with pin assignment or with pio interface with the pwm_hall module? --- Quote End --- Sorry, My problem didn't discribe clear enough. My problem is ablout the interface between the Core of SOPC and pwm circuit. I used the PIO to connect the Core of SOPC and pwm_hall circuit, but I find a problem. In my design, the output of pwm_hall doesn't work. However, I found a problem is the input of pwm_hall doesn't gat any signal form the output of Core of SOPC. So, my problem is PIO interface. How to solve this problem?? And I already confirm the circuit of pwm_hall is workable. Could give any suggest how to set that interface between the Core of SOPC and my pwm_hall?? Thank you so much.
