16 years agoProblem about the Pin planner of SOPC core
I bulid a system with SOPC builder. And I only use six components ,CPU ,JtAG Uart ,system id, Pio*3 and pll. The PIO that two is 16 bits output signal, the other one is 1 bit output signal. t...
16 years agoIn the schematic you posted, I see that g output pin seems to be connected to a bus wire. Is there a mistake or is it simply a problem with the bitmap image?
Anyway, please, explain better your problem. Which device works and which doesn't? The problem is with pin assignment or with pio interface with the pwm_hall module?
