16 years agoProblem about the NIOS II IDE c code
I don't know, dose anyone have the same problem with me?? MY problem is this... I want to printf the data from my NIOS II IDE to the *.txt file I try to use the "fopen" like this... --------...
16 years ago --- Quote Start --- Take a look at the host filing system for Nios II. It only works when debugging and is quite slow, but might suit your needs. -slacker --- Quote End --- Thank you for your suggest, but could you tell me how to use this method?? or Do you have any document, could you give me some advice??
