20 years agoProblem about PIO
Here is my code: # include <stdio.h># include <system.h># include "altera_avalon_pio_regs.h"# include "alt_types.h" int main() { alt_u8 led = 0x1; IOWR(0x00000800,0,led); pri...
20 years agoHave you set the direction? If it is defined as an output port only it might not be needed but give it a try. In NIOS 1 I found that the PIO component did as expected but in NIOS2 I have to tell the port to go into output or input mode as required.
Victor Schutte www.zerksus.com
