21 years agoProblem about LAN
HI all, i write a Web Server with NIOS and i need a documentation about the model Client/Server in NIOS. Can i help me? Do you use Berkeley's Socket? Thanks a lot, Gianluca
21 years agoI suggest you read chapter 8 of the Nios II Software Developers Handbook.
The answer to your question is that if you use LWIP and MicroC/OS-II you can just use sockets. You should probably look at the web server example which comes with the kit.
