21 years agoProble opening the /dev/epcs_controller device
Hi all, My application can not open the /dev/epcs_controller device for reading the EPCS flash. We do NOT have the probleem during debugging/running inside the NIOS IDE (thus downloading code...
21 years agoKwok,
The next likely place to look is in the initialisation code for the EPCS device. I suggest you take a look at the function alt_epcs_flash_init which can be found in the file nios2\components\altera_avalon_epcs_flash_controller\Hal\src\altera_avalon_epcs_flash_controller.c My guess is that this function is failing, which will cause the device not to be registerred and therefore you will get a null file pointer.
