21 years agoProbems with Quartus II software
I'm learning VHDL, using Quarus II software... I have written some functions which are not included in Quartus II software libraries. Now,I would like to use them in my programs but I have many e...
21 years agoHi Moutain8848, I've tried your suggestions and I have an other problem
When I call a function witch is written in VHDL language and usin only standard functions, everything works fine. But when I add an other library In witch I call some functions witch had been defined in the previous one I have a pyramid of errors... In order to understant really what I need, I suggest you to compile the source named inlet_test.vhd, using the appropriate libraries written in VHDL language. You can find them on http://bear.ces.cwru.edu/vhdl (http://bear.ces.cwru.edu/vhdl) website... Please, let me know if you have the same errors 'cause in fact I'm just beginning using Quartus II software... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Thanks
