20 years agoprob. in accessing UART
Hello ... i have written the following prog. to access my uart in my design it is named as "uart_0" in the SOPC builder.... while running this prog. in NIOSII IDE i was simulataneously running...
20 years agohello mr wolf
i am using EP1C6 UP3 BOARD supplied by altera(i.e sls corp. in turn) so the cd given by altera did not include any examples related to ep1c6 board so i had to go to sls example... plz help me out ..or can u give some info about ur bdf file(i,e ur example ) where this uart prog worked... plz help me http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif --- Quote Start --- originally posted by pfab@Dec 1 2005, 04:03 AM unless it is absolutly necessary to use the sls example wich is, if i am not wrong, an example for the up3 development kit, you should use the altera examples for your development kit.using the altera examples you will have a fpga configuration that is tested to work with your board, including the uart.
i am quite sure that the problem is not your code but the fpga design.
--wolf
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11284)
--- quote end ---
--- Quote End ---
