20 years agoprob. in accessing UART
Hello ... i have written the following prog. to access my uart in my design it is named as "uart_0" in the SOPC builder.... while running this prog. in NIOSII IDE i was simulataneously running...
20 years agoUnless it is absolutly necessary to use the sls example wich is, if I am not wrong, an example for the up3 development kit, you should use the altera examples for your development kit.
Using the altera examples you will have a FPGA configuration that is tested to work with your board, including the uart. I am quite sure that the problem is not your code but the fpga design. --wolf
