20 years agoprinting to 16x2 LCD module
i got this code from here (http://forum.niosforum.com/forum/index.php?showtopic=229). this code initialize the lcd module. #include <unistd.h># include <stdlib.h># include <stdio.h>
/* Comman...
20 years agoi also tried to modified from pio_lcd16207.h. i merely add in the main function, change nr_delay to usleep. this time, nth happen to the lcd module.
#include <unistd.h># include "pio_lcd16207.h"# include "nios2_system.h" /* Descriptions of standard peripherals */
static void delayShort(void);
// Device constants
// Internal LCD signals
enum{
LCD_E = 0x400,
LCD_RS = 0x200,
LCD_RW = 0x100,
LCD_DATA = 0x0FF
// LCD Device Commands
enum{
LCD_CMD_CLEAR = 0x01,
LCD_CMD_HOME = 0x02,
LCD_CMD_MODES = 0x04,
LCD_CMD_ONOFF = 0x08,
LCD_CMD_SHIFT = 0x10,
LCD_CMD_FUNC = 0x20,
LCD_CMD_RAMCGR= 0x40,
LCD_CMD_RAMDDR= 0x80,
LCD_CMD_FILLER= 0x00
// Device Parameters
enum{
LCD_INTERFACE = 0x10, // interface width;1 (8 BITS)/0 (4BITS)
LCD_NUMROWS = 0x08, //# of display rows; 1 (2 ROWS)/0 (1ROW)
LCD_PIXEL = 0x04, // character pixel; 1(5x10 dots)/0 (5x7 dots)
LCD_MOVE = 0x02, // character move direction; 1(increment)/0(decrement)
LCD_SHIFT = 0x01, // move character with display shift; 1(shift)/0(no shift)
LCD_DISP_SHIFT= 0x08 // action after character; 1(display shift)/0(character shift)
enum{
LCD_COM_RESET = 0x30
// Some LCD parameters# define LCD_BUS_WIDTH 8# define LCD_PIXEL_WIDTH 5# define LCD_PIXEL_HEIGHT 8
// The hardcoded definition of where the LCD lives at
// PIO port address
np_pio *lcd = 0;
void nr_pio_lcdcursorvisible(int bVisible)
if(bVisible)
nr_pio_lcdwritecommand(0x0E);
else
nr_pio_lcdwritecommand(0x0C);
void nr_pio_lcdon(int bOn)
if(bOn)
else
nr_pio_lcdwritecommand(0x08);
void nr_pio_lcdclearscreen(void)
nr_pio_lcdwritecommand(LCD_CMD_CLEAR);
void nr_pio_lcdsetcursor(int row, int col)
unsigned char address;
if(row > LCD_NUM_ROW)
row = LCD_NUM_ROW;
if(col > LCD_NUM_COL)
col = LCD_NUM_COL;
if(row == 0)
address = 0;
else if (row == 1)
address = 0x40;
else if (row == 2)
address = 0x20;
else
address=0x60;
address += col;
nr_pio_lcdwritecommand(LCD_CMD_RAMDDR | address);
void nr_pio_lcdprintstringslowly(char *string, int time)
char tempBuffer;
int i;
i=0;
sprintf(tempBuffer, string);
// Show as much of the string as we can...
while(tempBuffer)
nr_pio_lcdwritecharacter(tempBuffer);
usleep(time);
i++;
* nr_pio_lcdwritescreen(char *string);
* This is probably the most useful routine. It
* takes a string, and prints it to the LCD starting
* from the first character. If the string is less
* than 32 characters, fill the rest of the display
* with blanks. If the string exceeds 32 characters,
* truncate it. So sorry!
void nr_pio_lcdwritescreen(char *string)
int row;
int col;
int done;
int count;
count=0;
for(row=0; row < LCD_NUM_ROW; row++)
for(col=0; col < LCD_NUM_COL; col++)
nr_pio_lcdsetcursor(row,col);
if(string == 0x00) // hit the end and stick there.
nr_pio_lcdwritecharacter(0xA0);
else
nr_pio_lcdwritecharacter(string);
void nr_pio_lcdinit(np_pio *lcdPio)
static int beenInitialized; // uninitialized static variables get cleared each run!
if(beenInitialized)
return;
if(!lcdPio)
lcdPio = (np_pio *)na_lcd_16207_0; // pio in reference design...
lcd = lcdPio;
// Send first Reset
usleep(15);
nr_pio_lcdwritecommand(LCD_COM_RESET);
// Send second Reset
usleep(5);
// Send third Reset
usleep(1);
// Setup interface parameters: 8 bit bus, 2 rows, 5x7 font
usleep(1);
nr_pio_lcdwritecommand(LCD_CMD_FUNC | LCD_INTERFACE | LCD_NUMROWS);
// Turn Display Off
usleep(1);
nr_pio_lcdwritecommand(LCD_CMD_ONOFF);
// Clear Display
usleep(1);
// Setup Default Mode
usleep(1);
nr_pio_lcdwritecommand(LCD_CMD_MODES | LCD_MOVE);
//ON
usleep(1);
nr_pio_lcdon(1);
beenInitialized = 1;
void nr_pio_lcdwritecommand(unsigned char command)
// preserve the data on the lines, but clear the RS and RW line
lcd->np_piodata=(lcd->np_piodata & ~(LCD_RS | LCD_RW | LCD_E));
// output the RS and RW lines.. but nothing else
lcd->np_piodirection=(lcd->np_piodirection | (LCD_RS | LCD_RW | LCD_E));
delayShort();
// toggle the E line HIGH to latch the command
lcd->np_piodata=(lcd->np_piodata | LCD_E);
delayShort();
// output command word whilst E line is high
lcd->np_piodata=(lcd->np_piodata & ~LCD_DATA);
lcd->np_piodata=(lcd->np_piodata | command);
lcd->np_piodirection=(lcd->np_piodirection | LCD_DATA);
// toggle the E line LOW to latch the data
lcd->np_piodata=(lcd->np_piodata & ~LCD_E);
delayShort();
void nr_pio_lcdwritecharacter(unsigned char character)
// preserve the data on the lines, but clear the RW and E line, set RS
lcd->np_piodata=(lcd->np_piodata & ~(LCD_RW | LCD_E));
lcd->np_piodata=(lcd->np_piodata | LCD_RS);
lcd->np_piodirection=(lcd->np_piodirection | (LCD_RW | LCD_E | LCD_RS));
delayShort();
delayShort();
lcd->np_piodata=(lcd->np_piodata | character);
int i;
int v = 0;
for(i=0;i<50;i++)
v++;
int main(void)
lcd = (np_pio *)na_lcd_16207_0;
// Send first Reset
usleep(15);
usleep(5);
// Send third Reset
usleep(1);
usleep(1);
// Turn Display Off
usleep(1);
// Clear Display
usleep(1);
usleep(1);
//ON
usleep(1);
nr_pio_lcdon(1);
printf("LCD initialized.\n");
usleep(1000);
nr_pio_lcdwritecharacter('A');
printf("LCD written.\n");
usleep(5000);
return 0;
} Pls help! Thx!
