22 years agoprintf Problem with custom Board and NIOS II
Hello has anybody the same problem or an solution? I'm using a custom board with an stratix device and a NIOS II/f Debug Level 2. The NIOS II itself has a lot of user-defined interfaces, ...
22 years agoHello,
adding a JTAG_UART didn't solve the problem. There are also no memory conflicts in the design. It is also enough memory available (2 MRAM Blocks for system memory). So I try to find the failure with an simulation. Any other Ideas? MfG Chris
