22 years agoprintf Problem with custom Board and NIOS II
Hello has anybody the same problem or an solution? I'm using a custom board with an stratix device and a NIOS II/f Debug Level 2. The NIOS II itself has a lot of user-defined interfaces, ...
22 years agoIf you're using Hyperterminal ... ugghh! ;-) Try:
File->properties, Settings tab, ASCII setup button: check "Append line feeds to incoming line ends" box. --Scott
