15 years agoprintf() problem after IOWR and IORD
Hi I faced to a problem with prinf() function.. in my C code when I wrote printf() after IOWR nothing was displayed out. but all the printf()s before IOWR were displayed in the jtag window. I ...
15 years agoIf you don't do pipelined transfers you should remove the readdatavalid signal.
If you don't have variable delays either, you should remove the waitrequest signal and just reply to a read request on the clock cycle following the request. In the component editor just check that the read delay is 1 (which is the default value).
