15 years agoprintf() problem after IOWR and IORD
Hi I faced to a problem with prinf() function.. in my C code when I wrote printf() after IOWR nothing was displayed out. but all the printf()s before IOWR were displayed in the jtag window. I ...
15 years agomy slave custom logic is so simple because I'm just learning embeded design now.Is there any special signal that I must use in my module to tell to the cpu about termination? this module use one avalon_mm salve interface.
this code simply get a data from SW and put it on reg A,then put a 32bit constant data on red_data bus.
`timescale 1 us / 10 ps
module new_component (avs_s0_address,avs_s0_read, avs_s0_readdata, avs_s0_write, avs_s0_writedata, avs_s0_readdatavalid,avs_s0_waitrequest, clk, reset);
input avs_s0_address;
input avs_s0_read;
output avs_s0_readdata;
input avs_s0_write;
input avs_s0_writedata;
output avs_s0_readdatavalid;
output avs_s0_waitrequest;
input clk;
input reset;
reg A;
reg B;
reg avs_s0_waitrequest;
reg avs_s0_readdata;
always @(posedge clk)
begin
if(avs_s0_write && !avs_s0_waitrequest)
begin
A<=avs_s0_writedata;
# 1 B<=A;
end
end
begin
if(avs_s0_read && !avs_s0_waitrequest)
avs_s0_readdata <= 32'b00111111111111111111111111111111;
end
assign avs_s0_readdatavalid = 1'b0;
initial begin
avs_s0_waitrequest = 1'b1;
# 10 avs_s0_waitrequest = 1'b0;
# 310 $display("A = %h hex", B);
end
endmodule
