20 years agoPrintf failed
Hi all.
I using our custom board (2C35) and i have aproblem with IO. Everything seems O.K. (like r/w SDRAM) but simple printf("Hello world"); is not working. Is anybody have an idea why it do not work? Thanks at advance. Alex5 Replies
Alex,
That's not enough information to really help. What's your stdout device? What options have you set on your system library? Have you tried single-stepping into the printf(), to find out just where it's failing? Having this sort of information is mandatory. Best Regards, - slacker - Altera_Forum
Alex,
what kind of NIOS are you using!? A reference design or did you create one on your own?! You might have forgotten to add the jtag_uart or something, so the console is disabled... Good luck, Danny - Altera_Forum
Dear Danny and slacker.
1. We use Cyclon II. 2. My in/out/err device is jtag uart. Now about what happen : If i use in sys_lib options "small C library", printf is working, but it prints in console window just a point "." on every char or integer. If "small C library" option disabled, printf do not print nothing. ** May be it is depends to memory mapping of compiler, like stack (we had problems with the SDRAM before). Thanks a lot. Alex. - Altera_Forum
--- Quote Start --- originally posted by burdalex@Dec 6 2005, 06:08 AM dear danny and slacker.1. we use cyclon ii.
2. my in/out/err device is jtag uart.
now about what happen :
if i use in sys_lib options "small c library", printf is working, but it prints in console window just a point "." on every char or integer. if "small c library" option disabled, printf do not print nothing.
** may be it is depends to memory mapping of compiler, like stack (we had problems with the sdram before).
thanks a lot.
alex.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11350)
--- quote end ---
--- Quote End ---
Co-ask!
--- Quote Start --- originally posted by burdalex@Dec 5 2005, 01:16 PM hi all.i using our custom board (2c35) and i have aproblem with io.
everything seems o.k. (like r/w sdram) but simple printf("hello world"); is not working.
is anybody have an idea why it do not work?
thanks at advance.
alex
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11333)
--- quote end ---
--- Quote End ---
