15 years agoprintf does not display in the console
Hi All, I am trying to get the cycloneiii_3c25_start_niosii_standard reference design files to run on the cyclone iii starter kit. The problem that i have is that once the Nios ii project ...
15 years ago --- Quote Start --- I could not use a Jtag debug module in this case and so just flashed the .hex into the FPGA by buidling the C code and then compiling the quartus project. --- Quote End --- I never worked with such a configuration. I think that if you don't have the jtag debug module inside Nios you can't debug anything. Try to change something in system library configuration, for example mapping you code into a different memory.
