15 years agoprintf does not display in the console
Hi All, I am trying to get the cycloneiii_3c25_start_niosii_standard reference design files to run on the cyclone iii starter kit. The problem that i have is that once the Nios ii project ...
15 years agoAs you main() function is the entry point of your project, everything outside of it is also outside of your project directory. But your project is started through a BSP, which should have been generated when you generated your project.
With this in mind, you should be able to find alt_main() in <BSP-Project>/HAL/src/alt_main.c Are you using Jtag-uart or altera_uart driver an stdin/out/err?
