12 years agoprinciple of acquisition f=10MHz signal with nios software
Hi, i'm working on nios and i would like to acquire a signal that f=10MHz. I've a clock turning on 100MHz. I've tried many ways such as getting signal from main function. But the frequency th...
12 years agoI don't know how to use nios vga controller. But I read in a book how to make it. Resolution 640 x 480 8 bit color depth. It uses a 512K SRAM ( as frame buffer ) because timing scheme it's easier than SDRAM.
The fpga has a 50 MHz clock, so a pixel tick slow down to 25 MHz. Also, this pixel tick switch the address of the memory between the cpu and the vga controller. So, it's like a dual port access. But multiplexed in time. A state machine place the read and write signal of the cpu in the proper clock cycles.
