12 years agoprinciple of acquisition f=10MHz signal with nios software
Hi, i'm working on nios and i would like to acquire a signal that f=10MHz. I've a clock turning on 100MHz. I've tried many ways such as getting signal from main function. But the frequency th...
12 years ago --- Quote Start --- There is LPM_SHIFTREG megafunction. You could make from your fast 10 MHz input signal an internal wider and slower one. Let's say 32 times wider and then main function with 300 kHz perhaps could do the job. --- Quote End --- Thanks. My signal has 8 bits so it's datarate is 8*10MHz=80MHz and i have no so many input pins to parallelize them all.
