20 years agoPrecompiled headers
Hi all, I am new to Nios II, using Nios IDE 5.1 for a project and the first problem I'm facing is slooow compilation (and this is a P4 multipro 3.6GHz with 2GB RAM). I tried using precompiled headers but got an error:
sorry,unimplemented: had to relocate PCH Then browsing the web found this: http://gcc.gnu.org/ml/gcc-bugs/2004-05/msg00559.html (http://gcc.gnu.org/ml/gcc-bugs/2004-05/msg00559.html) But because I'm a Nios newbie I don't know what is required to fix this. I tried recompiling gcc but didn't succeed so far, and I'm a bit confused: Is the nios2-elf-gcc source provided within the niosII distribution? What is different between nios2-elf-gcc and gcc? I see the source of gcc but to fix the PCH problem I guess what I need to recompile is nios2-elf-gcc? Also any hints on how to recompile it? I tried recompiling gcc but was getting error: ld: cannot find -lgcc Thanx in advance, any help will be much appreciated!No RepliesBe the first to reply
