16 years agopre build binary chain problem
hello all Im trying to install the nios2gcc to my laptop with has Ubuntu Linux on it my laptop is AMD Turion X2 I followed the instructions on the wiki and changed the PATH variables to...
15 years agoThe permissions are as they should be. ls -altr shows the data is executable.
The Problem is not only limited to the nios2-linux-uclibe-gcc, all binaries do not work an bring the message "command not found". The $PATH is also as it should be. Using command line completition brings the demanded bins. But still I get "command not found"-error. I start to believe it is either a problem of the VitualBox or the distribution itself. I'm using Ubuntu 9.10. As far as I am concerned I'm can't immagine a reason for this behaviour. Regards.
