21 years agopower failure interrupt on NIOS 2
HI, I am busy with a design of an embedded system with Altera Cyclones with NIOS 2 and a LPC2106 ARM cpu. Have implemented RTC with battery backup, nonvolatile 32kB sram (simtek), a LT...
21 years agoBy default, the software looks for the highest priority interrupt which is pending and handles that. All interrupts are disabled while it is searching for that interrupt.
A low priority interrupt can choose to enable higher priority interrupts while it is handled (using the function alt_irq_interruptible), but this is only of benefit to slow interrupt handlers (those which take more than 50 cycles or so). If you call alt_irq_interruptable from a fast interrupt handler (as interrupt handlers should be) then this will result in a longer maximum interrupt latency.
