20 years agoPotential _interrupt_handler infinite loop
I added a 16550 UART FPGA Core and when receiving large quantities of data my system is locking up because it is in an infinite loop within the _interrupt_handler assembly code in vector.s. What I f...
20 years ago --- Quote Start --- originally posted by stefanlevie@Mar 16 2006, 06:10 PM the uart core was designed with level interrupts, but unfortunately there was a bug in the timeout interrupt where it was deasserted when the next data byte was received instead of when sw read the uart. changing this eliminated the problem. thanks for the help and pointers.
does anybody have any comments on whether or not the _interrupt_handler code should be changed to prevent an infinite loop?
thanks,
stefan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13523)
--- quote end ---
--- Quote End --- It's a bit of a tough one that, you can only get into the infinite loop with broken hardware, is it better to flag this with an infinite loop or ignore it?
