16 years agoPost-build Step not working
In NIOS EDS 9.0SP2 I have defined a Post-build Step command to perform a final conversion of the generated .elf file. However, nothing seems to happen. No message in the console, no visible ac...
16 years agoFound it!
1) close the IDE 2) edit lines defining BUILD_PRE_PROCESS and BUILD_POST_PROCESS in the Makefile 3) reopen and use the IDE -> it does not seem to throw away the changes 4) corollary : do not forget to put the Makefile under version control... P9
