20 years agoPosible Problem with ISR Edge PIO
Hello, This is more a theoretical view, but think it could be important to you. When working with an IRQ generating PIO with Edge Capture Register and multiple inputs, a ISR proccesing rou...
20 years agoIt is in fact how the hardware peripheral response to a read operation on its slave interface. I don't think you can do in software.
In Verilog HDL it should look like this :reg LatchedInput;
reg InputEdge;
assign IrqStatus = IrqEnable & InputEdge;
always @*
case (Address)
`IRQ_STATUS : Dout = IrqStatus; // read out the interrupt status
endcase
always @(posedge Clk or posedge Reset)
if (Reset)
begin
InputEdge <= 0;
LatchedInput <= 0;
end
else
begin
LatchedInput <= Input;
// this resets the input edge capture when reading the interrupt status
if (!nRd && Address == `IRQ_STATUS)
InputEdge <= 0;
//this sets the capture register, with higher priority than resetting
//when a new edge occurs just at reading the irq status, it will generate e new interrupt
if (Input && !LatchedInput)
InputEdge <= 1;
end Maybe there is a software trick for it like disabling interrupts, changing order of commands, ... I'm not an "Altera PIO component"-specialist, I usually roll my own. For the edge capture, I don't think the miss of an edge is so critical, what happens if a new edge comes in when the older is not processed yet? It is lost anyway. For this you need a counter to remeber how much edges occured.
