16 years agoPorting SoftFloat / TestFloat to the NiosII
Hi, I have a slight problem porting the SoftFloat Library from J.Hauser and its testing-application to the nios2. When I compile the code using the nios2-elf-gcc on the console, everything...
16 years agoits hard to be specific, but you should check your include and library path in IDE. Open properties. But of course your should first make sure the compilation is working, then bother about the linker.
