15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoLet me see ... Nios will do the loop in 6 clocks ... assuming the timing measurement by PDPGY is accurate, then ARM must be doing the loop in 1 clock to get the 7 to 1 timing.
This fails the sanity test.
