15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoWhy not adding a cache between NiosII-e and the external memory ?
Reinhard, your NiosII-e runs @ 50MHZ as well as your SDRam. By placing a cache between NiosII-e and SDRam this could speed up your execution. Such a cache (with wishbone interface) is used by the zet project and available as verilog soure. maybe it is time to write a wrapper around it that it acts as a slave to NiosII but and as a Master to SDramIP Controller ... This verilog source can be parametrized in deep and size
