15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoIf you are careful, and are executing code from tightly coupled memory, it is possible to avoid almost all pipeline stalls. This will give you one instruction per clock.
You will need to inspect the generated code though, and modify the source in places (mainly to avoid register spills, stalls due to 'late result' on memory reads and mispredicted branches).
