15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoThe other Nios cores are definitely faster, but I don't think they reach a 1 MIPS/MHz ratio though.
You can evaluate them without paying, the only thing is that you won't be able to write the design to flash, and will need to keep the USB connection on while you run your application.
