13 years agoPorting non-mmu code to MMU -- MMU memcpy SEGV
Thanks in Advance. With the non-mmu nios2 our design defined sdram regions that we utilized for buffers in our custom device driver. **** device driver sharedMem = kmalloc( SHARED_MEMSIZE...
13 years agoUPDATE and QUESTION(S)
I got the memory working. The thing that I am unclear upon and would like to understand is the "special node" for the mmap area? I have the device driver open "/dev/myDDriver0" -- which is MAJOR - 240 and Minor 0 I created a node locally in the directory I'm running the test code: mknod node c 204 0 (same major and minor# ) I HAVE to do an open on that too. CODE snippet *********************************************** if ((fdPlayback = open(DevName, O_RDWR | O_NONBLOCK | O_SYNC)) < 0) { perror("DevNameIO"); printf("error opening device %s\n", DevName); return -1; } if ((fd=open("node", O_RDWR|O_SYNC))<0) { perror("open"); exit(-1); } So I open that one too and do the "mmap" and all is well. So - why this special node (why can't I use the file pointer from the device driver open)? Could someone provide me with some reading to understand this? I'm going to need to have 2 more memory areas and would like to know what that is going to entail
