21 years agoPorting Nios II Flash Programmer
Hello all, I am currently working on porting the nios II flash programmer to a custom board. My board is basically the same as the 1s10 dev board, but I have repinned the nios II standard build t...
21 years agohello mtmurphy,
Can your system run&debug program? To download software&hardware configuration with flash programmer , you should make a target board according AN346 step bysetp. Your meaning you can't generate target board, isn't it? and can you post the error information?
