20 years agoporblems when generate the zImage
hello guys, i have encounted a problem and came for your kind help. to generate the zImage file, i input the command 'make', then it has the following errors, what should i do? need to ma...
20 years ago --- Quote Start --- originally posted by bigmagic@Jun 12 2006, 09:37 PM hippo,thank you for you kindness, i will try it when i get back to the lab tomorrow.
another question, what's the size can a smallest uclinux be? is it able to be uploaded to a flash of only 2m byte?(with kernel and the file system)?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16124)
--- quote end ---
--- Quote End --- The smallest size of compressed kernel (with initramfs) is around 600KB. It will grow if you enable more kernel config or more apps,data etc. The compression rate is around 1:2 . If you didn't use complex programs such as ssl/ssh , 2M should be enough.
