20 years agoporblems when generate the zImage
hello guys, i have encounted a problem and came for your kind help. to generate the zImage file, i input the command 'make', then it has the following errors, what should i do? need to ma...
20 years agohippo,thank you for you kindness, i will try it when i get back to the lab tomorrow.
another question, what's the size can a smallest uclinux be? is it able to be uploaded to a flash of only 2M BYTE?(with kernel and the file system)?
