20 years agoporblems when generate the zImage
hello guys, i have encounted a problem and came for your kind help. to generate the zImage file, i input the command 'make', then it has the following errors, what should i do? need to ma...
20 years agothank u very much hippo, i added a timer in the sopc builder and the problem is solved.
i compile the kernel under linux, but now that, it shows cannot find nios2-elf-gcc, i should install something else? thank you again.
