21 years agoPoor performance with LWIP and uCOSII on NIOSII
Hi there,
I'm using a niosii system using data (2kb) and instruction cache (4kb) and running ucosii and lwip, and based on an ip gbethernet mac core. With a very simple (and stupid ...) application, I benchmark the overall performance of this system with a UDP streaming. The first results concern me a lot: globally the low level (Interrupt handler, home made driver and VHDL IP core) runs quite well : interrupt latency => 7usec delay in the interrupt delay in (Transmission mode) => 6usec DMA transfert => 10,6usec (for 1024 bytes) however, even with a simple loop at the application level to send a given number of udp packets (no superfluous job), the first results give me a maximum throughput about 5-6 mbits/sec which is very low. Does someone have any figure to confirm or to invalidate my results with an equivalent system ? Thanks in advance. Gaël3 Replies
Your figures are in line with what I would expect, what's your target?
If you look at the topic "lwip MicroC/OS-II throughput" in the MicroC/OS-II Forum you will see that 17MBits/s UDP Rx and 35MBits/s UDP Tx have been achieved. - Altera_Forum
What do you mean by target ? I'm using a Stratix 2S60 on altera evaluation board.
Do you have an idea about the system configuration used to achieve 17Mbits Rx and 35Mbits tx ? Was it on the altera evaluation board using a standard design ? Gaël - Altera_Forum
Sorry I meant what's your target performance?
As for the information on the system, all I know is what's in the posting I referred you to.
