Pointing IDE to different folders...
This is a very basic question. How do I point the IDE to a new but existing project. The scenario is that someone sends me a quartus/SOPC/NiosII/IDE project tree and I unzip it onto my local drive. I have my own project(s) in the IDE pointing to other systems and they work fine. How do I repoint to this new, but existing project I've been sent? Or maybe another way to ask is to how do I open this project? I don't want to create anything new, I just want to open an existing project and start workiing with it. Thanks, Ken6 Replies
I'm not sure if I understand your question, but have you tried "File->Import project" ?
Yeah, I select the project and it gives an error saying "Project Already Exists". Go figure http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Ken - Altera_Forum
Import them one at a time (I hope they didn't send you 30 projects or this will take a while). Once you have imported the application project and the system library it is associated to you are all ready to go.
Sounds like the projects have the same name. If that's not the case look at the navigator and C/C++ projects trees (it may be in only one of them)
if you already have a project with that name, you cannot import it again.
either do - you first have to delete the existing project from the navigator (you must not delete it from the hd, "do not delete contents") - rename the project you want to import by manually changing the name in file .project - Altera_Forum
Well I've gotten closer. I deleted all the projects I had (I'll have to deal with that problem later) and imported both the project and syslib projects one at a time as BadOmen suggests. Seems to go well, but a build/rebuild gives an error that the .ptf is needed:
the entire error is: "*** No rule to make target `C:\qdesigns\neuralog\stratscan\stratscanner.ptf', needed by `C:/SRC/2004/stratscan/software/hello_world_0_syslib/Debug/system_description/../obj/generated_app.mk-t'. Stop." The .ptf file is now in C:/SRC/2004/stratscan. This is set correctly in the System Library Properties, so I don't know why its looking in C:\qdesigns. Where else do/can you set the .ptf location? It would be real nice if I could just Open Project..., Browse for a/the project file and go to town. Too much to ask I guess... Thanks, Ken
