14 years ago
Please help me ......SDRAM DE2
:( i have a problem.....my project need to use sdram on de2 board altera...but i dont know to use sdram......some master help me....
i use sopc to configure a sdram controler on my system......
but i dont know to program c to access it.....i mean to read or write on sdram through sdram interface or anything....
thank so much......
    Recently I have came upon these issues you are facing, and believe I can be of some help:
    1. Follow this tutorial to integrate the SDRAM memory controller to your NIOS II processor: "Using the SDRAM Memory on Altera’s DE2 Board" (just google it, I can't provide you the link)
    2. The SDRAM CLK must have a 3 ns phase delay from the Avalon interface clock. Besides using a PLL with a "-3 ns" delayed output, you must define time constraints accordingly.
    3. You can read/write from/to the SDRAM using simple I/O macros, such as:
    int val=123;
    IOWR( SDRAM_BASE, SOME_OFFSET, val );
    val = IORD( SDRAM_BASE, SOME_OFFSET);
    4. It is also possible to declare variables in the SDRAM because it is memory mapped, just like the internal SRAM memory. I haven't done that yet, but I have read it from a pdf file I found on google.
    5. Something I noticed when I was testing the SDRAM is that there are some memory positions at the beginning and at the end of the memory that don't work properly (at least in my DE2 board). So I only use the following range of addresses:
    SDRAM_BASE+2048B < range < SDRAM_BASE+8MB-2048B
    As you can see I'm only throwing away 2KB (0.025%)... I was able to successfully write to all other memory positions.
    Thomas.
